"can low coolant level cause a
"can low coolant level cause an alarmat WOT and stop alarm when i back off? 6.2mpi fwc inboards 74hrs used from spring 04 to dec 05 than winterized and sat till now . boat was surveyed 2 weeks ago with rinda/merc scan port 165 @ idol 176@4596rpm starb. 163@idol 170@4722rpm WOT. since than oil/filters ,h2o sep/filters,and seawater impellors replaced and changed now analog port is 175 and starb is 180. again analog. also the hull sea strainers which were slotted were replaced with scoop type great south bay strainers(smaller holes to prevent eel grass in pumps(long island so. shore problem)would the smaller holes mean i need a diff. thermostat since merc say it comes w/170 deg stat i think.? oil psi on gauges is good. coolent level i will check tommorow morn. but resivoir on both sides looked low and starb almost empty..can low coolant cause hotter temps w/o overheating? at what temp does merc alarm sound?? 180?190?175? if coolant level is good than where do i go next...thanks in advance guys..."
