I have 2004 Mercury Outboard 90 HP. Last year the alarm started going off if you exceeded 4200 RPMs so we replaced the water pump impeller and gaskets. Ran approx 10 minutes and solid alarm would go off again. Pulled water pump back off and impeller was burned at the hub even though it was run in water. NEXT: replaced water pump base an gaskets, impeller, base plate and gaskets and water coupler. Same results. NEXT: we replaced the thermostat and power head base gasket. No change. NEXT: we replaced the exhaust plate gasket if ran under a load of 4200 RPMs it would run all day long, but exceed that for any length of time the alarm would go off. NEXT: replaced the sensor in the engine. No change. NEXT: I took it to a aluminum welding place that specialized in Pontoon Boats and he drained the pontoons, but said that there wasn't that much water in them and that he could not see any damage to the pontoons or anything that would cause any water diversion or issues when he had the boat off the trailer. NEXT: I had the water jacket gasket poppet valve kit with gasket replaced and theromostat replaced. And did tune up while there at the end of year as well including sync and link on engine. ALL of the above repairs have been done by a Mercury double certified licensed mechanic so not just a back yard person doing the work.
Put in the water the first time last weekend. Now I can not exceed 4000 RPMs so I lost max RPM;s that I can drive around at before it goes off. But water pressure is more steady and not bouncing around like it did last year.
Does anyone have any other ideas of something to try??? Getting very frustrated. We do not abuse the boat or drive in shallow water, never in sandy areas to pick up anything in the engine.
Thanks for any help you may have
