All,
Just started my outboard (with ear muffs over water pump area) the first time in 18 months - after an extensive storage period of non-usage.
It ran fine up to 3 minutes - then an alarm sounded at the console and i turned it off. I do not know if this alarm was caused by overheating or another tigger…
- the fuel is new.
- water pump/impellor is new (installed just before layoff in 2008).
- new thermostats and confirmed that they do open at the right temps (installed just before layoff in 2008).
- cleaned out cylinder ports and removed all salt grime/buildup after removing heads.
- no cracks / warp in cylinder heads.
- good / even compression from all 4 cylinders.
- fairly healthy water flow from piss hole.
- water does splash out from the propellor area.
- water supply pressure from tap not the strongest IMO.
- both heads were hot to touch.
- all water deflectors in block have been replaced and are not swollen.
Questions....
- best way to test ohms for temp sensors and in what type of oil bath?
- what temp/ohm triggers off the sesnors?
- how to determine if the water supply pressure is sufficient to prevent possible overheating?
- how to determine if this alarm is triggered by a strong vacuum in the fuel line or another cause?
- does a vacuum switch exist on this motor (if so where exactly)?
- where exactly are vacuum switches normally located on other motors?
Advice on next steps to diagnose this problem would be much appreciated......
Byte
- the fuel is new.
Questions....
Byte
