Alarm engine stalled
robbie_lee
Hi guys my searay stalled on m
Hi guys my searay stalled on me after a run out at sea i was on low revs around 5 knots engine just died would not restart alarm bleep twice when ign turned on smart craft come up with tps fault when turned battary s of then turned back on she started up ok been ok since but 2 fault codes vdc low and tps voltage low 50l mpi 2004 mercurser just dont want be towed back again if i have a fault
cheers
"At the risk of stating the ob
"At the risk of stating the obvious, you had/have a low voltage condition. Check the charging system and battery condition. Don't worry about the fault/alarm, it only will be active as long as the low voltage condition exists. It will go away when the problem is corrected."
thanks dave
checked my batta
thanks dave
checked my battarys today all ok plus boat alt is giving out 14.2 on idle will take boat back out for a run and hope she dont break down . just dont under stand turning battary swicht of then back on then it started .bit like rebooting a computer
cheers
"just dont under stand tur
"just dont under stand turning battary swicht of then back on then it started"
Dirty cable connections and internal contacts on the battery switch. Clean with TUNER cleaner from Radio Shack.
