Alarm and surging engine
No gauge flashing. All normal. Oil not low in either tank. Pump was replaced too.
Do you have a Yamaha multi-function tachometer? Are you saying that all three oil bars are illuminated steady state and that the over temperature bar is not flashing?
With the key off, inspect the pink wire to the warning buzzer for a connection to ground. There should not be one. The buzzer is grounded to cause it to alarm. If you are not seeing anything amiss on your tachometer then perhaps (a wild guess) the ground wire to the buzzer has been chaffed to a ground source.
Is this something that just started on a motor that you have been using for a while without any problems?
