pinkhippo72
Hello,
I have a 1997 Mercury 175 EFI. I have been having some issues with it to include running rough at idle, stalling at idle, and difficulty starting. It has new gas and we have replaced all the filters, checked and replaced lines, installed new pulse pump, checked vapor separator float and tank as well as electric pump, and had the fuel injectors sent to Brucato for cleaning. After the injector service it ran much better but there is still an issue. Also we have done quite a bit of troubleshooting on the ignition system to include new plugs and spark confirmation. Also checked the timing and its fine.
Today after it wouldn't stay running for me I removed the fuel line going into the water separating filter and it just blew pressurized air out with a "whoosh" sound, not a drop of fuel going into the filter. With the line removed still I pumped the primer ball and out gushed fuel as its supposed to. Reconnected the line and still wouldn't start for me.
Any ideas what might be causing the air in the line? Thanks for any advice!
Meg
Meg
