Aggravated1986 110 vro someone help please
J
jeff oelshlegel
Guest
"just aqquired a 17 ft chappre
"just aqquired a 17 ft chapprel 178xl with a 1986 110 vro. the boat is really nice and i got it for nothing, so i took it. well, it was in the water when i got it, and i had planned on pulling it out so i could do some routine maintanance. Because i know the previous owner neglegted it pretty badly. Well, i didnt really know how much until i started tearing into it. i got the lower unit off (took lots of penetrating oil and lots of heat, still going to have to drill out 2 bolts).... anyways, got the water pump housing off, ok but now i cannot get the impeller to move, and i mean AT ALL. I gotta tell you, i have done lots of these things before, and never in my life have i saw anything this bad. it is frozen on there. usually after playing with them a little bit i can get them off. Not this one, it just WILL NOT pop off. Im getting really frusterated because its the only thing stopping me from putting everything back together. i sprayed it with pb, tried everything i could think of. I thought of cutting it off, but i dont have a cutting wheel right here and i wanna find out of thats safe to do first. now i know what happens when a motor is neglegted this badly, it looked like the original friggen pump. i know its probably not, but the impeller was so worn, not broken, but worn down to almost nothing. no womder it wasnt pumping water. just irritated. t stats are out, new ones are ready to go in, but i want to get over this hurdle first, so anyone got ideas ?"
"Cut off the rubber and try to
"Cut off the rubber and try to split the hub or try to lock the prop shaft (in gear) use the prop and a piece of wood, and twist the impeller counter clock wise 1/8 turn to loosen it from the shaft."
