n36511
Ok, so the last few weekends I have been able to get the boat out some and have a problem that happens occasionally that I need some help identifying. On the warmer days (mid 80s temp) that I have been on the lake, the boat runs great.... usually cruise around 2300rpm..... but when I pull back to idle it will idle just fine for a bit but then dies. No the really odd part is that I cannot get it restarted unless I let it sit for about 30 min to an hour. It just turns over but it is almost like it is out of gas. Engine temp looks fine (2 gauges). On cooler days I don't seem to have this problem. It is a twin engine boat (engine specs below) and both engines share the same fuel filter as well as gas tank. The other engine does not experience this problem. Any thoughts on where to start troubleshooting this one?
AQ145a 280 outdrive
900 hrs
Thanks for any help you can provide!!
AQ145a 280 outdrive
900 hrs
