jimthorley
hi new to forum looking for someone with knowledge. just bought a boat with a mariner 50 hp elpt 4s. been having issues ordering right parts it now seems this unit can have 3 different gear boxes with mine being a light weight unit. is there advantages or disadvantages with having this light weight unit? on first outing in boat the motor started first turn of the key but couldn't get boat up on the plane a 50 hp is the max my shetland 498 is rated for. the engine surged now and again and had to just cruise back at slow speed as was putting boat up in the air but just seemed short of getting up on the plane. i have since serviced the unit my self new plugs new fuel filter.oil filter oil gearbox oil flushed and changed. compression test not to bad but only doing on cold as unit stopped running traced it back to fuel line and primer bulb then male connection was broke so have renewed all and done the impeller too engine starting right away again but no water pumping up but stripped bottom leg to find pump housing tube was stuck to top end so have re fixed but no water still when on muffs SHOULD there be water right away? or does engine need to heat up before thermostat will open to let water flow to pee hole? have decided to take to loch in case muffs not supplying enough water and will give me a chance to tune engine as i messed about with fast idel and enrichment screw before finding fuel system was falling apart. can my unit take the other gear boxes or is the one have good enough THANKS TO ANYONE who can shed some light on all of this for me
best regards jim:rolleyes:
