" After changing the water pum
" After changing the water pump and impeller on my 1986 Evinrude 225, the engine started to overheat (Alarms sounds) at low rpm's. I could run the engine above 1000 rpm's and it runs perfect without overheating (No alarm), with water coming out of the pee hole even at low rpm's. After troubleshooting and changing both thermostats found that there is a bend in the brass tube that carries the water up to the engine. I asked the o/b tech at the shop and he told me that the reason that the engine only overheat at low rpm's is because there is not enough water being put out thru the water tube due to the bend. But when the engine goes above 1000 rpm's there is enough presure to force water up the tube. He said that to replace this water tube is a major job, because the power head needs to be removed. My question is, have this ever happened to anybody out there and if there is another way to fix this other than removing the power head. Any advice is appreciated, thanks. "
