87point2psi
Hi all,
I've aquired a 200 optimax from my brother in law. He's not much of a boat guy and bought this used engine for his pontoon boat, after realizing it was slightly overkill, he purchased a smaller 4 stroke...long story short..I ended up with this beast in my garage. "Apparently" it was a good running engine, however I got it without any wire harness or controls...just the engine.
First off I'm a boat guy, and have had many two stroke outboard, BUT..nothing newer than mid eighties...so this newer technology ecu controlled engines are way ahead of me now ,so I'm lost with it.
I'm a Volvo penta guy so really, I have no use at all for this engine.
I have ordered the correct wiring harness from Ebay with the round 8 pin and key switch and should be here in a few days. I DO NOT have the rectangle plug smart gauge harness yet.
My plan was to flash this engine up on the stand, confirm it runs, do compression check etc, and sell it off....but now I'm thinking this may not even be possible given I'll only have the one harness.
My questions for you guys in the know:
-Am I able to start this up with only the one harness or do I need the full smart guage setup before it will run?
-If I can't run it without spending a fortune first, is there a market for used parts for these things? I was thinking if I cant run it and prove it as a working engine that maybe I can dismantle it and get rid of it piece by piece.
Now that I have it in my garage, I've realized how large and space consuming it is, I just want to figure out a plan to get them out.
I appreciate any advice you mercury gurus might have to offer! Thanks in advance!
87
87
