Adding Sea Foam to the oil
westsider
"1989 OMC Ford 5.0 ho
O.K. Fi
O.K. Finnaly got all the bugs out. (crosses fingers, knocks on wood, and does a dance to appease the boat gods) What do you folks think about oil additives?"
"My 2 cents....I personally do
"My 2 cents....I personally don't believe in them, just regular oil and filter changes."
If you put Sea Foam in the oil
If you put Sea Foam in the oil it will change the visco.. outy..?? well you know what I mean I think. Sea Foam is for the gas not the oil. I use it in the fuel.
"Well I will just use it in th
"Well I will just use it in the fuel. The reason this came up is when I read the can it says to put half the can, pint size, in the oil to "increase R.P.M.s vacuum and compression". But as Bill points out, regular oil changes should do the same thing, I think."
