Adding a fuel pump to Merc 4 HP Gnat, help needed
I would install the little square fuel pump used by Johnson / Evinrude.-----Used on 3 to 25 HP motors from 1968 to 2005 model years..----Simple / reliable.----Likely easy to install.----Easy / cheap to find on Amazon.
No such thing as a 3 HP 4 stroke in 1968 !!----And they use 2 hoses on that little pump.----But you could modify to use a third hose for the PRESSURE pulse.
This link was on Marine Engine.com/Youtube. It shows a 4 HP Gnat with an added fuel pump. The fuel pump was added because these Gnat's were famous for not gravity feeding. I'd like to know what fuel pump was used as these are very tight quarters. Was it a small electric pump? Something had to provide the pulse but on this engine I can't see that happening. Larry
