AD41P-A w/DP-E outdrive
I picked up this 26' skipjack knowing that it had rust on the oil pan. Well, it just started leaking and I'm going to pull the engine. I've been reading the forum and there's alot of you that are very knowledgeable and I'm hoping that you can give me some advise.
Is there anything in particular that you know of that will give me problems during this process or is it pretty much straight forward.
Anything eles that I should check while the engine and outdrive are out.
Thanks and wish me luck!
