"Have a 1994 Wellcraft 2700 fi
"Have a 1994 Wellcraft 2700 fitted with AD41 200HP engine. Currently have 630 hours.
Last year at 580 hours after cruising for at least 20 minutes, when throtling back to idle,
at 600rpm, the oil warning lamp and buzzer would come on.Oil pressure meter would read about 1.5 bar.By increasing revs to 1000 for one minute the light buzzer would go off and engine idling at 600 rpm, oil pressure meter reading almost 2 bar.Volvo mechanic suggested that we change
some springs(Volvo Kit) in the oil sensor/pump.
Those were changed, as a result the cold start oil pressure has increased to about 6-7 bar instead of 4-5 and the hot engine crusing oil pressure is about 5.The oil warning light/buzzer would still come on when idling after hard driving for about 20 minutes again been resolved by going to neutral and increasing revs to 1000 rps for one minute. Now the buzzer/light require more than 1500 rpm to stop and do not stop after even two minutes of keeping the revs there. I entered the marina in idle speed buzzing all the way to my berth...Engine does not consume any oil. How do I fix this? Note that we installed an oil pressure dial directly to the engine and compared the readings with the Volvo dial and they are slightly better. So the oil pressure switch works but the oil warning light and buzzer
still sing! What do you think is the problem? Faulty oil buzzer/light sensor OR...."
