"I am trying to decide if it i
"I am trying to decide if it is worth the time and money to troubleshoot and repair an engine of mine. Scenario as follows:
Second owner since 1992. Engine well maintained, ran excellent. Pickled and sat for four years. Started right up, idles like a gem, falls on face when throttle is applied under load.
Compression as follows: #1 - 145, #2 - 140, #3 - 120
Pulled head. #1 and #2 cylinder walls within spec. #3 slightly out (0.0029", limit is 0.0020"). Decent amount of piston slop. A rebuild is obviously in order, but I do not have the time at the moment.
I reinstalled head with a new gasket, then dropped the carbs, tore them down, soaked them and put them back on. Now the engine will only idle with 3/4" choke.
Am I wasting time here with such a large variance in compression? Like I said, before pickling the engine ran excellent; smooth idle, adequate power.
One last item: a black oily, soupy mixture is draining from the prop exhaust. I have ruled out fogging oil because I have run the engine long enough, have cleaned the inside of the cylinder walls and cleaned the carbs. This NEVER occured before, when the engine was running well. Thanks."
