"1980 Merc 115 has recently st
"1980 Merc 115 has recently started hanging up at about half throttle (~2000 RPM) while accelerating. I wouldn't describe it as "bogging down," more like something is sticking and it kind of sputters and knocks for a bit if I hold the throttle in that position, and then eventually kicks in and continues to accelerate normally. If I try to advance the throttle before it "kicks in," it dies. Otherwise it's running fine at idle and WOT.
My first thought was something was binding in the spark advance system because of the subtle knocking and the way it eventually "breaks loose" and smoothes out. Any thoughts on this behavior being ignition vs. fuel related and what to test?
If it was caused by insufficient fuel flow it doesn't seem like it would exhibit such a distinct change between sputtering and then suddenly flowing again. But could it be a float or valve sticking?
As an aside, there are two grease fittings on the distributor. I've lubed the lower fitting until grease comes out of the collar above it but I'm not sure what to look for if greasing the upper fitting (distributor shaft?). It seems to be taking a lot of grease. The shop manual has nothing about it. Suggestions?
Thanks,
Scott"
Thanks,
Scott"
