I have a 1997 Mercury 25 hp electric start, I changed out the water pump on it, and now the throttle linkage is messed up. Forward seems to work along with neutral. The problem is with reverse, it acts like the throttle cable isn't adjusted correctly, and it will go into reverse if manually helps. If you don't manually help it shift to reverse, you can litterally take the tiller handle and spin it past reverse and not shift the linkage, I assume maybe the cable is to loose or needs replacing?
