bill_griffiths
Hi guys
haven't posted on here for some time as everything has been going fine.
I have a 225d engine and 285 drive (electro-mechanical tilt with power steering). Ever since I have owned the boat (over two years now) reverse gear has been difficult to engage. The engine tickover is correct and forward has always engaged easily. On recommendation I checked the cockpit control which is perfectly free with no cable attached and then proceeded to fit a new shift cable making sure that routing, clamping etc was correct. This appeared to ease the problem but not fully rectify it.
Last season we were on a trip up the coast when the drive 'jumped' out of gear and the engine revs went sky high. I immediately throttled back and discovered that all was fine until the engine revs went above 3500 when it would do exactly the same again. Since then engaging reverse has been a progressively harder task up until the point that at the end of last season I could not engage reverse at all - the control will just not move bacwards.
My question is this - in your opinion could the cone clutch be seizing, sticking on it's shaft to the point that it is not fully engaging forward - hence the slippage - and totally refusing to move to engage reverse?
My boat is in the water all year round and it is frighteningly expensive here to have her lifted to dry dock plus the daily charge for hard standing. I would like to be reasonably confident of what the problem is before I have her lifted as once out I need to fix it as soon as possible and get it back to it's mooring.
I know that there are some true experts out there on these drives and would appreciate any help you can give me.
Many thanks in anticipation
Bill
Bill
