A new undertaking
oldjak
"I have recently aquired an ol
"I have recently aquired an older bass boat with a 73', 65hp evinrude. However the control box is shot. As many of you know a new control box for this year of outboard is almost unheard of unless you want to spend about $350 on a box and a wiring adaptor, and quite frankly I don't have that kind of money to blow. And I really don't want to put someone elses piece of crap control box (bought off of e-bay) on my boat. So I've done my homework and I can get A new Uflex control box, a kill switch, and a new key switch with push to choke for less than $200
. What I need to know is how to wire the thing, the new switch is going to have 6 terminals. and I need to install the kill switch (i have no idea) The wiring is conected to the motor with the red plug. I havent torn anything apart yet or purchased the parts. To the best of my imagineation this is perfectly plausable, right? I am quite mechanicly inclined I've just never tackled a boat. The control box should'nt be an issue. It's the wiring that I'm concerned with and what to expect when I peel this banana. Oh, I almost forgot, thiers no trim or tilt, so thats not an issue ether."
"wiring that,wont be a prob...
"wiring that,wont be a prob...r sure,u have a 73?..a 69-72 evin would have a push button,and a diff animal shifting wise."
"The title says its a 73'
"The title says its a 73' and it is a manual shift I know that for a fact, its got the two cables from the box to the rude. But what wires go to what terminals on the ignition/choke is where I'm curious, do they come with detaled instructions or what colored wires mean what for the "red plug" style harness? And if you might know of one(ignition/choke) that is better than others for my application that info would be appreciated as well."
Black GROUND
Gray Tachome
Black GROUND
Gray Tachometer Signal
Black with Yellow Stripe Shorting or Stop Circuit
Red Un-fused Wire from Battery
Purple Ignition (Switch) to 12 Volt Positive
Tan with or without Stripes Temperature Switch to Warning Horn and/or
Temperature Sender to Temperature Gauge
Yellow with Red Stripe Ignition Switch to Neutral Start Switch
to Starter Solenoid
Purple with White Stripe Stripe Choke (or Primer System)
