I needed the three bellows replaced and a water pump impeller replaced so I took the boat to a shop. Other minor repairs were done and the final cost was $1800. OK. But when I get out on the water the bilge starts and there is a significant leak of a quart every ten minutes. The leak is there with the motor running or not. I get the boat home and tilt the boat back and fill the bilge with water to see where the leak is and it appears to be primarily near the new gear shift bellows. I call the repair shop and the owner tells me to bring the boat in. It never had such a leak before the bellows were done. Not a drop. I just spoke to the owner who tells me he pulled the outdrive and there is a loose bolt sticking out of the transom assembly that may be a sign of dry rot in the transom or maybe a gasket and he needs to pull the motor (for a thousand bucks) to see if that is the problem and then if it is fixable. He tells me his work has nothing to do with the leak. Now I want to give every one a fair shake but can anyone tell me if the boat shop owner is being straight with me. Or, am I just a sucker? Have him fix it (again) or pull it out of there. Any ideas, comments?
