"I have a 4.3l Mercruiser in a
"I have a 4.3l Mercruiser in a 99 Bayliner Capri.
It has been running fine, sometimes a little run on (dieseling), but other than that, it has been fine.
One day a few weeks ago, it stalled in the middle of the lake, and took a lot of cranking to get it going. That problem re-occured once, but on both occasions, it started again. I chalked it up to running rich (which I thought was also causing the run-on - not sure).
Yesterday, plopped it in the lake, turned the key, and it was completely dead. Turned the key again, completely dead. Third try, it started turning over - but would not start.
Ran down battery trying to start it, then used booster pack and still no go.
Yanked it out (with a smile on my face ;-) and brought it home. Charged battery, still no start.
Measured power at positive side of coil, and very light current at negative side (maybe drain?) Popped a new cap and rotor/pickup set in, no go. Swapped in another coil (not sure if right one) and still no go. Power at coil again, and nothing at all at negative side - not sure if this has fixed a problem or introduced one.
Disconnected and re-connected main wiring harness in engine compartment (added some dielectric paste for good measure)
Snipped one of the emergency cutoff wires at throttle lever in case switch was defective - still no spark, fixed wire
Every time I changed something I checked for spark at the coil and spark at a plug - never got one.
Not sure what to check next.
Any advice on what to check would be appreciated.
Thanks in advance."
Thanks in advance."
