apollobeach
"Looking at buying '99 Wel
"Looking at buying '99 Wellcraft Sportsman 210, with '99 Ocean Runner 175. Having it checked out now. Mechanic says compression spread is 95-110. Upon first check, the range was 90-110, but after a de-carb, the spread tightened a bit. I see a 10-15psi difference is the threshold, so it's at the limit. All else checks out...no leaks in drive oil, motor runs strong, test spin on the water was fine. Opinions on if I should pass on this?"
