T
TJ
Guest
"I purchased this boat last ye
"I purchased this boat last year. The first time I took it to the lake (6000')Elevation. The boat idles great, gets up on plane fine, then when I start cruising my Tack hits 3800 RPM's and my speed is only 28MPH then my RPM's start to jump up and become irratic and the engine starts to back fire and cut out, but the engine volts show steady at 13. Its been back to the dealer 2x and they can't seem to find the problem. I have changed the cap, rotor, wires, plugs, fuel filter, oil and gas. Still does it. Any ideas what might be causing this? I have two props 14.5/19 3 blade and a 14.25 x 20 4 blade, doesn't matter which one I use same problem."
