basstard123456
I have a 99 Johnson 115 Produc
I have a 99 Johnson 115 Production date is 10/1998 Model J115PlEEM
Boat has never been in salt water.
I was making a long run with the boat about 14miles when I noticed a small but short misfire only every so often As the days went by it got worse & at first it was only under WOT but now its at half throttle or sometimes as I am trying to get on plane.
I thought I had got bad gas & I put some Sea foam in the tank the next day it was just as bad if not worse.
I did lot of reading on here & saw lot of boat with similar problems but I have not formed a plan of attack just yet.
First checking to see if it is an over heat problem the suggest to remove the brown wire & ground it to see if the over heat horn sounds I have a light not a horn but yes it works so that eliminates heat.
I have about every gauge & light a bass boat could on this ride.
I Pulled the fuel filter or what I would call a screen It seemed to be fine no major clogging Are there more filters??
I removed the plugs all look good & did a compression test 90+ on all 4
I did find one of the seal rings missing on the air box so that explained the small amount of oil in motor compartment.
Next test I guess would be to take it on the water & try pumping the ball when it happens but it will be hard to tell because it happens but then recovers very fast.
I have heard that the fuel pumps on these can go bad but again it feels like a spark misfire.
I have been a car mechanic for 20+ year so I am no stranger to engines I would like to diagnose & not just put parts on till its fixed.
