99 johnson getting 14volts to charge battery
S
steviewonder
Guest
"Is there an add-on part to th
"Is there an add-on part to this motor, so I can put a battry on board, for lights, bilge pump? at the moment, no DC volts available for this, from what I can see. Thanks steviewonder"
"If You have three yellow cabl
"If You have three yellow cables (Yellow/blue. yellow/gray, yellow) lying 'loose' in the engine, You may add a diode rectifier and get DC voltage for charging, but not much.
If no cables, You have to add a lightening coil under the flywheel as well."
