99 Johnson 250HP TampT problem
sphinx
"Hey all.
I have a 1999 Joh
"Hey all.
I have a 1999 Johnson 250HP with T&T problems.
I have manually lifted the engine and checked the fluid reservoir and it is full. Once the engine was up, the lift rams came out when the T&T controls were pressed but they went back down once the weight of the engine was placed on them.
}I released the screw for the manual release then tightened it back but the motor moved up about one inch and then came back down very slow.
When the T&T control is pressed, there is a sound as if the reservoir was empty. I have tried this numerous times but I still have not been able to get the T&T to work properly.
Any assistance would be greatly appreciated."
"system is 'basically'
"system is 'basically' self bleeding...raise it all the way up,refill w tnt or pwr st fluid,run up and down 5 times,..refill,.........continue process once more...if that does not help,..u have internal probs."
