scottmckee
I'm new hereand would appreciate any guidance. I have a 1999 Johnson 200 (J200PXEEN)on my 21' Grady White. The voltage gauge is reading 18+ volts atanything above idle and not much less at idle. I have dual, maintenancefree, deep cycle batteries that can either be run in "both" (which Inormally do) or either battery individually. I just replaced one ofthe batteries that was completely dead. I originally suspected that itwas charging high because of the dead battery, but it still reads high nowafter it was replaced. I am concerned that I might nothave noticed the high rate of charge and that led to the batteryfrying. On the other hand, maybe it was just time for the batteryto fail, and I have bad voltage gauge...
My questions are: How can I trouble shoot this? Can I just put a voltagemultimeter across the leads to the voltage gauge? If it is still18+ volts, do I have a bad voltage regulator? I have researched them-arethere differences between OEM and aftermarket? How difficult is it toreplace? Advice on replacing it? Thank you in advance!
