99 200 hp Johnson Outboard
M
Mike Gardner
Guest
The check engine light/alarm
The check engine light/alarm goes off on my engine and I can't find the problem. It runs great but the alarm goes off. Any suggestions?
" I believe that is for the va
" I believe that is for the vacuum sensor. When there is a fuel restriction between the fuel tank and the motor, the sensor sets off the alarm and the check engine light. There is a possibility that the sensor could be bad. One way to check it is to run the motor with an auxilary fuel tank. Another is to run the motor with a vacuum gauge installed in the fuel line. "
