northernterritory
As you all probably know, I've pretty much went through the entire engine and its components. I have had the cylinder head worked by a machine shop (valves were not seating, head was warped, head gasket blown, block was still level though; looks like someone allowed it to overheat since the water pump wasn't work correctly). The manifold is new, starter is new, new supply water pump impeller and seal, new cap and rotor, new plugs and wires, rebuilt carb with new brass float, new fuel filter, new belts, and new gaskets. I'm probably leaving off a few new things as well. What started all of this was a crack manifold. There was also detonation. I am hoping this was caused by the cylinder head issues or carb, and not a flawed fuel pump.
Now that I am about all back together, I need to start thinking about my re-starting checklist. Here is what I thinking and questions I also have.
* I set the float in the carb to be parallel with the body, as per the directions, and the idle screws in their original position. I also checked the power valve lever gap, and it is in-spec. I assume the carb should be good to go?
* I'm unsure how old the gas is, so I am going to completely drain it. Once I re-hook the fuel system up, the fuel filter bowl, the carb, and all of the lines will be empty. Any special procedures to prime the carb?
* Should I install an in-line fuel pressure gauge, or borrow a tester from an auto-parts store to make sure my fuel pump is working correctly? Or, should I just run it and look/listen for the signs of a lean mixture? I know I need to do this in the water; running about idle on tongs is bad idea.
* Will using the garden hose tongs around the foot adequately fill the entire coolant circuit, or do I need to fill it from up around the t-stat as well? I know impellers do not like to be ran dry.
* I know I should re-adjust the valves and re-torque the manifold bolts after a heat cycle, and also re-torque the cylinder head bolts after 20hrs, but is there any other things like this I should do?
* Should I install a water-seperator fuel filter?
* Anything else?
* Anything else?
