I have a Suzuki DT150 that kee
I have a Suzuki DT150 that keeps shutting off when shifting in forward or reverse. Changed the neutral switch and changed the throttle position sensor and tested range.
It seems that the timing is not advancing when shifting.
I also checked the all linkage and have the correct measurements.
RPM drops to about 550 to 650 rpm when shifting out of neutral.
Gear tooth counter seems to be working
Motor tend to load up after I try to go into gear.
