jacobnorthwest
"I AM DEALING WITH A VMAX 225
"I AM DEALING WITH A VMAX 225 YAMAHA WIRES SCHAFFED AND BURT THROUGH 4 PIN RED BLACK BLUE BROWN ON ENGINE BLOCK FROM STATOR TO COMPUTER ENGINE DIED WAS TOWED IN NOW I HAVE IT REPAIRED WIRES ENGINE STARTS RAN ON HOSE FOR ABOUT 10 MIN THEN ENGINE DIED WILL RESTART AND RUN OR TRY WHEN YOU GIVE THROTTLE IS DIES LIKE RAN OUT OF FUEL IT HAS 37# FUEL PRESSURE AT ALL TIMES WINKY BLINKY FLASHES 1 TPS SMOOTH TRAVEL AND HAVE RE SINC WITH OHM METER ENGINE WILL RUN ON LIMP MODE AND NOT DIE ON EXCELLERATION BUT IS VERY RICH HELP!!!! WOULD ONLY LIKE TO BUY THE DEFECTIVE PART OR PARTS NOT THE WHOLE MOTOR COMPUTER?, STATOR? RELAY? I AM NOT SURE IF I AM LOOSING POWER TO INJECTORS OR NOT I HAVE GOOD FUEL PRESSURE AND O2 SENSOR IS GOOD I HAD A NEW ONE AND PUT IT IN AND NO CHANGE BATTERY IS CHARGING STATOR OUTPUTS OK @ CRANKING"
