OK I did this no one else to blame. replacing solenoid the old one was not marked "I" or "s" and I have messed up the wiring and now nothing when key is turned no gauges, no tilt/trim motor function, no starter turn over. if i take the cable from battery connect directly to starter it turns over.
1998 Mercury 40 hp serial number oe339698
Wires I have are
1 large wire one from battery one large terminal
1 to the starter and a bundle that I assume goes to everything else Both go to the other large terminal
1 red and yellow wire goes to small terminal "not sure I or S"
2 small black wires separate terminals goes to other small terminal "not sure "I or S"
2 red wires going to same terminal Maybe to mounting bolt for solenoid
what can I do?
Wires I have are
what can I do?
