Hello. I recently bought a Bayliner boat, with 98 Mercury Force 90HP motor. I tested the boat on the water with the seller, everything was great. Compression was around 130 I believe, on all 3 cylinders. Got it home. Next day went on the water, and it wouldn't start. Fuel film started to appear on the water when trying to start. Next day, it started, drove for about 20 miles, then at the dock, I put it to idle, and it stalled right away (prior to that, it was always at throttle). Once it stalled, I wasn't able to start it. Tried starting it home, I noticed there's fuel leaking from the carburetors. It's hard to say if it's coming form the top and is going through the other 2, or all 3 are leaking.
Where/what should I start with? What I should I check? What could be the problem? And what will it take to get that fixed?
I am not a mechanic by profession, but I'm very hands on.
Any help is appreciated in advance.
