It seems to me that by using the spark tester that when the motor misses the fire goes away. See if you can see it on the video. http://youtu.be/7Egv2IplhMs
That dont look like an adjustable air gap tester. You want the spark to be able to jump a gap of at least 7/16 inch brite blue snap. Have you done a compression test? Give us some compression numbers along with a model number of the motor. Pull all the spark plugs and check the compression with the engine cold. To protect the ignition system ground all the plug wires while checking spark gap and compression.
You need to check all the plug wires with a spark gap tester. We are looking for spark intensity.
