98 Johnson Ficht 175 Electrical Ignition
filb
"Okay. Again I have problems s
"Okay. Again I have problems similar to Seth. My trim gauges don't work, the voltmeter gives inconsistent readings, and I'm not entirely convinced the RPM's are reading true. Last time out I also noticed a "touchy" ignition switch. Could this be related to the gauges not reading? It's a '98' J175FSXECS."
"Great, no we may start.
Star
Start by pulling apart and re-connect all harness contacts between engine harness and extension harness to remote.
If you have no alarms but 'flickering' instruments and key switch. it is most likely a contact issue.
A thin layer of electric grease/Vaseline in the contacts may help.
Do the alrm system work as well as the 'count down' in the System Check gauge? (rev-counter lights)"
The alarm system/count down sy
The alarm system/count down system does work.
I'll start there but bare with me I'm not real marine engine savvy yet. Where are these harnesses? More specifically the extension harness/remote.
"It is an extension cable goin
"It is an extension cable going between engine and remote/instruments, On engine side it comes in on stb side in the lower cover. Just follow it, and it 'ends' in a lot of contacts into the engine harness itself. Pull apart all contacts, check/clean and put them together again.
Do the same on instrument/remote side of the extension cable. Even clean battery cables at both battery end and engine end, particularly ground cable."
Thank You I'll start there
Thank You I'll start there. It'll be a little till I get to this. I keep the boat away from home. Thanks Again.
