I bought a 1999 Crest 22' pontoon last fall with this engine on it. Dealer said both carbs had been rebuilt, water pump, plugs, etc. replaced and engine fluids replaced, along with new battery. Has been always a little hard to start and keep running sometimes. Left approx. 15 gals of fuel in tank over winter, after adding stabilizer (didn't run engine after adding). This Spring has gotten worse at starting and this past weekend, used 3 qts of oil over 30 gals of gas. Local dealer says it's got some blockage in fuel system, or oil pump is going bad. Running some "Sea Foam" thru it now, but would like to hear from others on this issue. Is the excessive oil consumption causing the hard starting by fouling the plugs?
Wayne
Wayne
