Sorry in advance for the long read, just want any info I can give to be out there.
I have a 1998 Evinrude 150 ocean pro. M# E150EXECD It has been winning the battle with me.. Currently when I try to start, it will turn over but seems labored and slow and not fire up and after a very short time it almost acts as if the battery is dying (brand new battery)
First off, when I bought the boat it started and ran. was out one day and it stalled and wouldn't start. Noticed gas pouring out of bottom 2 carb throats.
Action so far:
While plugs were out I noticed they were visibly saturated with fuel and oil. Cleaned and dried plugs then reinstalled. Engine fired up/ ran and idled great, let it run for a while, shut down. Waited a few hours and started again, ran great and idled as it should. let it run again about 20 min, then disconnected fuel line and ran all gas out of carbs until it died.
Next day: pumped up fuel line till hard, and no start. back to square one of it sounding labored and struggling to turn over.
Any ideas anyone has would be greatly appreciated.
Action so far:
- replaced fuel line/ primer bulb
- rebuilt all carbs (new floats, needles, bowls, gaskets, and adjusted to spec)
- replaced leaking and failed VRO with fuel pump VRO bypass kit
- checked fire on each plug with spark tester/ all had fire although I'm not positive on strength of spark
- New battery/ all connections cleaned and inspected
- complete rebuild of tilt/trim(unrelated to problem)
