bruce_raskin
"I am having a problem with my
"I am having a problem with my 97 DT 200. It started bogging down, you give it the gas and it just lurches if anything after being on the water 5 minutes or so. It will crank and idle great all day and will run at high rpm fine for about the first 5 minutes. I changed plugs and the water seperator, which had a considerable amount of water in it. The plugs I took out were wet with gas so I think it is getting the fuel Where should I look next. Any help appreciated."
