W
whiskey99
Guest
" My Mariner 40hp will only st
" My Mariner 40hp will only start if the button for cold start is engaged. Since it starts, I assume its in neutral but the prop still turns and accelerates if I increase power and I can't get it into reverse at all.
Prior to this happening I had removed the gearbox assembly to check for leaks...did I misalign something? I took it off again and the shift shaft appeared to be connected, but after the second reassembly the console throttle won't advance up unless I keep that button in....it will go down.
I also can't find a service manual for the engine, so I'm going from the diagrams at mercury parts express...any help greatly appreciated...its electric start and power trim. "
