Just need to double check with you guys before I order a new regulator/rectifier unit.
I bought a used 1997 35hp johnson that run fine but has some issue with the tach, it shows rpm on idle and up to about 1800rpm then settles at zero until I back off the gas and it starts to live at 1800 again and backs down to idle.
I tried measuring the stator using a digital multimeter according to joereeves guide, set to the diode check setting no wires seemed to register on the meter but when I changed it to resistance it read between 300-500ohm on all cables in one way and infinate in the other except when I checked between the two yellow wires and the "box" (ground I guess) that showed 300ohm one way and about 500ohm the other way. this seems awfully high to me but I don't want to replace the part if it's still fine. What do you think about it?
Best regards
//Magnus
Best regards
//Magnus
