Dear Experts - Joereeves, Racerone, anyone!
I've just replaced the entire ignition system as tests were done along with a bunch of stuffs were out of range (starter solenoid, stator, optical sensor, powerpak). The last component went on was the timewheel plate, spark came back nice and clean on all 4cylinders. Wrapped everything up (flywheel/rectifier cover, lower cowling, etc...) installed the control back on the boat, hooked up the muffs, cranked, cranked, cranked, no fire. Rechecked the sparks=all gone off again. Cut the kill wire at powerpak: nothing, disconnect the rectifier: nothing, disconnect all connectors to the control harness, jump start the starter to crank: nothing....I am back to square one and hit the stone block. Please give me an insight as what could have killed the ignition system quickly as such?
I have strong battery w/great cranking amp and everything. I will do a DVA test all over. But I am banging my head because what can simply cause this? A ghost? ;-(
Thanks for any advice and hope many other boaters and mechanic can view this as a sharing experience!
