Hello, all--New member here--
I have a 97 Evinrude 8HP that I bought on Craigslist about 3-4 weeks ago that hadn't run for at least a year. It ran fine when the seller demoed it for me before I bought it. I got it home and first thing I did was replace the plugs and gave it new gas at 50:1. It starts on 2nd or 3rd pull when cold and runs great at speeds up to about 1/2 throttle. Then, when I advance the throttle, it will not increase speed. Still runs fine, just at only about half speed even though I may have advanced to WOT. I sprayed OMC Engine Tuner thru the carb as per instructions, and it cured the problem for a day or so, then after sitting idle and not running for a couple of days, problem is back. It is intermittent. Problem will sometimes go away when I have throttle advanced to 3/4 or so of WOT (but the motor is only running at RPMs of 1/2 the throttle setting), and it will sputter a 1/2 second, then RPMS will go to the 3/4 or whatever setting I have the throttle advanced to, and run fine at the high speed for awhile. Then, a day or so later, no high speed again. I have run the OMC Engine Tuner thru it about 3 separate times to have it run fine for a day or so, then back to its problem. I've got a new fuel pump ordered and should arrive in a couple of days, but the old one looked fine, and I don't think that is the problem. Should I try Sea Foam? Trying to avoid a carb rebuild.
