fenderjake
Hello Folks, brand new to forum looking for some guidance. Like i said 97' 115hp Johnson, recently inherited from my uncle. My apologies if i don't use the correct terms. Trim and tilt has worked fine forever. Last day of boating last year my uncle said the tilt would not go up, and there was no sound of motor trying to work.
then i got it last week. looking at it this year, we got the sound back (motor trying) in both directions, but it won't respond
Reading through the forum we thought we had a low fluid/Airbound issue with the trim/tilt then we notice that the tilt isn't even going up. We do hear the motor running when the switches on the drive lever or engine itself is used. Here's where we're at.
1)- Trim Pistons were slow to respond. upon filling they stated to work better, but would only work one at a time, (right side first followed by left very slowly) and would never go down when trying to use the switches, and could be pushed down by hand when fully extended without hitting the switch.
2) We can hear gurgling in the unit when we manually lower the motor all the way down and compress the pistons.
3) trim pistons will come out a little, (using up switch) but are never strong enough to lift, and tilt piston never engages.
Any help is greatly appreciated,
Thanks so much
-Scott
Thanks so much
-Scott
