JeffinColorado
My initial phase of getting the engine running found the top spark plug was a weak spark and the bottom plug with no spark.
The points are in good shape so I filed them flat and set the gap to 0.20.
The plugs are new: Champion J8C Gap set at 0.025 (Clean and dry)
I tested the condensers, then switched their position with no changes in the spark.
The coil primary winding has less than 1 ohm resistance. The secondary coils are (Top) 6.66K and (Bottom 6.59K)
The spark plug wires are okay as best, but not burned or shorted to ground.
The point cam is in the correct orientation with the word "TOP" on top.
I'm starting to think, water, oil, grease may be shorting the system somewhere.
Any advice would be appreciated.
