New forum member here but can see there are very knowledgable people here and hope you can help where to go with this. When say hot i'm talking 180 to 190 degrees
Motor ran a cool 165 degrees prior to this issue. When it happens the temp gauge will creep up to 180-190 and then like enough pressure has built up and water gets passed a blockage the gauge will shoot down to 160-170 then start over again. This problem seem to developed while sitting over the Nov-May winter of 2013. During the off months I installed some new hoses, T-stat and housing, filters, belts etc. The sea water pump is 2 yrs old so I'm reasonably sure the impeller is OK and there has been a physical inspection and "looked" OK.
I have read some about flappers deteriorating and causing issues so I pulled both risers and elbows to ck them and only the starboard pin was remaining. This was the second set due to the holes for the pin was rotated about 90 degrees off from the original. I siliconed and taped them all shut and removed the remaining pin and reassembled.
I pulled the exhaust bellow and used a fiber scope to look thru the Y-pipe and found nothing.
Can a flapper that has falled off restrict the exhaust/water outlet so as to run hot.
I"m ready to install new manifolds and risers due to the boat being 18 yrs old as well, any suggestions?
I have successfully ran the motor on muffs to 165 degrees while fixing other items and will exceed that on the muffs now suggesting and circulation issue if you can't push water thru the motor, hence mannys and risers may be in order.
A bit wordy I know, I look forward to any thoughts from the forum...
Thank you in advance
Dan
Dan
