randy_hester
WHILE IDLING THRU SHALLOW WATE
WHILE IDLING THRU SHALLOW WATER I HIT A SUBMRGED OBJECT. IT DID NOT HIT HARD.PROPS ARE FINE. NO DAMAGE AT ALL.CONTINUED TO FISHING GROUND WHERE PROBLEM APPEARED. WHEN ENGINE IS PLACED IN REVERSE AND ACCELERATED IT LIFTS OUT OF WATER AS IF THE REVERSE LOCK IS BROKEN WHICH IT DOES NOT HAVE.UPON INSPECTION OF FLUID LEVEL IT WAS EXTREMELY OVERFULL.TRIM STILL WORKS WITH FLUID LEVEL AT WHAT IS NOW FULL AFTER IT DRAINED DOWN.ENGINE STILL RAISES IN REVERSE.TECH MANUEL SHOWS A HYDRALIC BREAKAWAY.HOW DO I FIX THIS PROBLEM? I CAN GRAB BOTTOM OF ENGINE AND PULL IT UP.THE OTHER ENGINE DOES NOT DO THIS.PLEASE HELP-AGGRAVATED TO NO END.
