96 mariner 175 efi will not run cold temps
Elishaman
1996 mariner efi hard to keep running when first starting at temperatures below about 37 degrees. Once you get it to keep running for 3-5 minutes it is fine. Starts and idles perfect at temps above about 40 degrees. I have checked the air temp sensor and engine temp sensor. I replaced the fuel filter. Fuel pressure is about 39psi which is above specs by 3 psi so I can't imagine that is the problem. Have owned since new and always used pure has or added stabil if pure gas not available. Always kept in my heated basement.
