New to me boat, so pulled lower end to check impeller..looked brand new (had done the kicker and it had broken fins)
Problem, when trying to reinstall lower end, get to <1” from seating and hangs up
Yes, in forward, rotated prop(thus drive shaft) and it has engaged motor spline
Yes, water tube is seated into tube on impeller housing fully.
no, it is not the shift rod preventing it from going further.
believe it is the water pipe that is preventing it from full insertion...remember having similar problem on a Merc year’s ago...but cannot remember solution ����
Tried inserting just the water pipe into the head...lots of hangup areas on the way up. When it felt like it was at it’s highest point, did not feel like it was being held by anything. Thought there was a grommet up there?? If I let go of pipe, it would just fall out. Is that normal?! If there should be @ grommet up ther3 and it’s missing/damaged, what is the process to replace it??
Because the pipe is rather “floppy” , tried using a piece of rubber between the pipe and the drive shaft to maintain the distance between the two, but do not know the Center to center distance to maintain.
Anyone have any other suggestions, tricks, etc? And answers to the grommet questions?
thanks in advance!
thanks in advance!
