Seeking info from you guys as I know your experience. Have a 1996 150 HP Ocean Pro E150EXEDB. Tilt stopped moving. Motor sounds normal both on Up and Down. With motor up and supported outside rods will extend on up and can manually be pushed in on Down. Center Ram does not move on either. Raised- filled reservoir / lower-repeated several times. No change. Turn manual release valve counter clockwise several turns, then clockwise and seated tightly. Again repeated several times. Leaving seated. No change. Any idea's?
